What are member and what are the method in my code.
Gajyamadake
Joined Oct 9, 2019
310
Hi All,
I am Just learning c++ about classes and trying to understand the difference between member and method
My code : I have written my own code
Code:
#include <iostream>
#include <string>
using namespace std;
//A class can be created before main() is called.
class person
    //The access labels Public, Protected and Private are used within classes to set access permissions for the members in that section of the class
  public:
    string name;
    int age;
int main()
  //Create an object of person and  then creating separate objects for the two person like this:
  person person1;
  person person2;
  person1.name = "sunil";
  person1.age = 15;
  person2.name = "Gajya";
  person2.age = 16;
  cout << person1.name << ": " << person1.age << endl;
  cout << person2.name << ": " << person2.age << endl;
  return 0;
When I compile code it shows detail name and age of person 1 and person 2
I don't understand what are member and what are the method in my code.
any help will appreciate
Thanks & warm regards
Gajya Madake
Papabravo
Joined Feb 24, 2006
22,111
A member of a class is a piece of data. A method of a class is a function or procedure operates on member of the class and potentially other data as well.
BobTPH
Joined Jun 5, 2013
11,638
Yes. And your class has no methods.
A method is a function declared within the class. Here is your class with a method added:class person{
Code:
   //The access labels Public, Protected and Private are used within classes to set access permissions for the members in that section of the class  public:
    string name;
    int age;
    void setName(string newname)
        name = newname;
You could then use the method like this:
Code:
    person p;
    p.setName("Bob");
Bob
Gajyamadake
Joined Oct 9, 2019
310
Bob
Thank you Bob
This code has method
Code:
#include <iostream>
#include <string>
class person
  public:
    string name;
    int age;
    void setName( )
        cout << "Bob";
int main() {
    person p;
    p.setName();
  return 0;
402DF855
Joined Feb 9, 2013
271
"Method" isn't really valid C++ terminology. What you probably mean is a "member function". (See The Annotated C++ Reference Manual p. 174).
Members are defined for classes and may be data, functions, enumerations, bitfields, friends and type names. (p. 169-170.)
