What amount of current or voltage cause shock hazard?
You mean, if i connect or sort both terminal with my hand then i'll die14V at 3A won't hurt you unless you intentionally try to hurt yourself. There was a story circulating about a guy who strapped the terminals of a car battery to each arm then got into a bathtub full of salt water, but who would be so stupid?
If your adapter was really made by Samsung then it is probably fine. There are some cheap adapters that do not have adequate isolation between the power line and the output and those have killed several people in recent years.
