What am I?
AlbertHall
Joined Jun 4, 2014
12,651
I doubt it is anything that fancy. It is essentially just a weight in a model train loco. It is used to carry power from the track to the motor and I am modifying it to add a DCC decoder so I need to modify this connection and so to connect a wire to this piece of metal. It is N gauge so there isn't much space to add e.g. a screw connection.
As I have discovered that I can solder to it with plumbers solder my problem is solved but I am curious as to what it is.
AlbertHall
Joined Jun 4, 2014
12,651
It is lighter and harder than lead but probably softer than steel. It has a black coating which seems to be conductive. I suspect it is diecast if that helps.
Lo_volt
Joined Apr 3, 2014
373
Model railroad trains that I've seen, typically older ones, used an alloy that I've heard that was called "base metal alloy". In doing a web search on base metal it is defined as non-ferrous metals such as copper, lead, nickel and zinc. The alloys on those trains were probably heavy on the nickel, lead and zinc with some amount of magnesium or aluminum as well. It was often used in diecast parts.
That's probably what you have. I've never tried soldering the "base metal" alloys from model trains, but every epoxy that I've tried did not hold well.
Ian0
Joined Aug 7, 2020
13,248
Probably a zinc-based alloy known as “monkey metal” - a fairly random low-quality alloy that is probably made from the sweepings-up from the workshop.
Ya’akov
Joined Jan 27, 2019
10,285
If it's a dedicate weight, it might be Babbitt (sometimes erroneously called "white metal"). The black coating might indicate protection against handling lead which is a concern of course.I would expect Babbitt to be easy to solder, tough.
AlbertHall
Joined Jun 4, 2014
12,651
Yeah, so it is probably some random mixture of metals to keep the costs down. I didn't know such things existed so I've learned something new - thanks.
It would have been a problem connecting wires to it, but I do have a method of soldering to it so all is well.
