Weller solder gun
kconnell
Joined Mar 9, 2018
6
I'm at a loss for understanding the design of the trigger action of the Weller dual temperature solder gun. In order to obtain the highest temperature, one must pull the trigger half way. To obtain the lowest temperature, one must fully pull the trigger. This seems in reverse to normal human behavior. Does anyone know why Weller designed it this way?
mcgyvr
Joined Oct 15, 2009
5,394
First guess:
They figured that most people are more prone to just go full squeeze on a trigger (potentially not even realizing there is a half setting) so logic would say to set that for the "safer/lower power" setting to prevent most people from overheating everything..
Most people don't need to be running a soldering device at max..
kconnell
Joined Mar 9, 2018
6
First guess:
Thanks mcgyvr, that sounds believable. Apparently the company that makes this item just don't trust its customers.
MaxHeadRoom
Joined Jul 18, 2013
30,801
It could just be to avoid the normal intuitive action of switching it on full with a full-on pull.
Preventing accidental overheat of component etc.
Max.
mcgyvr
Joined Oct 15, 2009
5,394
Thats not really a bad thing.. and of course all assumptions as I didn't design it..
But
Always best to fall on the "idiot proof" side.. The world is full of far more idiots than not..
35,127
By guess is someone wired the switch incorrectly. Mine doesn't work that way.
I don;t remember mine working that way either.
I haven't used mine in years. I know I had a plastic knife and smoothing thingy with one of them, but I'm not sure if it was the Weller. The other one I remember was a Wen.
Reloadron
Joined Jan 15, 2015
7,926
My old, as in my fathers 50 year old is two stage with low to high but the newer Weller 550 Model soldering gun:
  • Professional heavy-duty gun
  • Dual-heat wattage gun
  • Fingertip trigger selects high (1st trigger position) or low output (2nd trigger position)
  • Or low output (2nd trigger position)
  • Heavy gauge, high efficiency, tin-plated copper tip
  • Twin lights illuminate work
  • 2-wire cord
  • UL and cUL listed
Apparently I never got the memo from Weller? Nobody tells me anything! :)
Ron
35,127
Apparently Weller has two different styles of operation.
Here is the instruction for Weller 8200 Soldering Gun. Every Weller gun I have used works this way.
