Wave Winding
brian25
Joined May 13, 2013
37
1. An armature pole triplex wave-wound armature carries a total of 660 amps. if there are eight brush arms, calculate the current in each armature windings path and in the brush arm.
2. A 17 slot 33- segment armature is wound simplex wave for four poles. calculate the coil commutator pitches and specify whether or not there will be a dead element.
33,203
This is Homework Help, not Homework Done For You. You need to post YOUR attempt to solve YOUR homework problem. That will then serve as a springboard for steering you back onto the right path, if necessary.
