Wall wart output 9 VDC - need 4.5 VDC or less...
likes_shiny_things
Joined Sep 11, 2011
34
I want to use a wall wart to replace 3 AAs in a string of micro lights.
I have a wall wart that is rated at 3.7 volts, but it measures 9 volts with no load (it was originally for a cell phone).
How can I regulate that wall wart so it puts out 4.5 (or a little less if I want the lights to be not as bright)?
(I did a ton of searching and while there are many threads online that address similar issues, I found none to answer my question).
Thank you!
MaxHeadRoom
Joined Jul 18, 2013
30,768
Most likely the Wall Wart is a linear supply, they rely on the rated load current to bring them down to the rated level.
Wall Warts are cheap so you could just buy the correct one!
The other alternative is a LM317 set up for the voltage you need.
What is the current?
Max.
dl324
Joined Mar 30, 2015
18,444
How much of a load does the wall wart need to drop to 4.5V? What is the load from the lights?
likes_shiny_things
Joined Sep 11, 2011
34
The wall wart says 0.35 A
If you need to drop the voltage further use one or more diodes (1N4004 or similar) in series for 0.6V drop per diode.
Thank you for the diode suggestion.
The lights draw 66 mA. I got the wall wart to go to 6.9 V with a 100Ω load - that's the lowest value resistor I have.
likes_shiny_things
Joined Sep 11, 2011
34
Three rectifier diodes (1N4001) should drop the voltage by about 2.5V.
So, are you suggesting the three diodes (in series) in addition to the 100Ω resistor in parallel with the load? If yes, what's the minimum rating for the resistor?
I appreciate everyone's responses.
AnalogKid
Joined Aug 1, 2013
12,226
Since you don't know the exact circuit or components inside the wall wart, or more importantly, the transformer characteristics under light load, depending on the wart's unknown output impedance to form a voltage attenuator with the load is risky and not stable. As the transformer core heats up during operation, the voltage across the load will change.
Nothing will give you a more predictable output than a series pass regulator. I suggest a 7805 with a small power diode (1N4002, etc.) in series with the output. This will give you a relatively stable 4.3 V -ish output.
ak
dendad
Joined Feb 20, 2016
4,641
Why not just get a 5V plugpack, often for free from an old phone, or for not much at a Salvos store or almost any OpShop...
Then, add a series diode, 1N4007, and it will be 4.3V or there abouts.
