Completed Project Voltmeter needle goes only half way on Heathkit IM-5228 VTVM
Rahulk70
Joined Dec 16, 2016
538
Can you tell what kind of pots they are? Carbon composition pots, even now, have broad tolerance for the end-to-end resistance. ±20% to ±30% is not out of the question. Wirewound are usually better. Typically you can feel a bit of roughness when you turn a wirewound.
I'll leave it to you to verify, but it appears to me that the pots may be shunted by other resistances, depending on the function switch setting (I always do best with that sort of thing if I have a paper copy of the schematic and get out my crayons).
It's the normal 10K carbon pots. After some cleaning they seems to have come close to the 10K range. I'll recheck all the resistors again and see.
MrAl General Science, Physics & Math 9
