hello people
I need your help once again, so I have got this battery tripping unit it is supplied by two sources, one is 220VAC supply and the other one 30VDC from the batteries. what happens is that when the AC supply cuts off due to power failure or something the DC supply from the batteries kicks in. so now what I need is a circuit that will monitor the AC supply, if it drops below 100VAC or lost completely there should be an alarm which will serve as an indication that the power is lost. I hope I have explained clearer.
thank you in advance
