Voltage measurement across Inductor
Electronic_Maniac
Joined Oct 26, 2017
253
Hi All,
I have read the previous threads regarding the voltage across the inductor but unable to get clarity.
Can I measure the voltage across the inductor with a Multimeter?
What if its an series inductor (Pi filter) at the input of an IC and what if it is at the output of the buck converter?
Please explain
Thanks.
Alec_t
Joined Sep 17, 2013
15,156
The average budget multimeter won't be able to measure accurately very small AC signal voltages (such as might be found in a pi filter) or non-sinusoidal voltages (such as those at the output of a buck converter).
Electronic_Maniac
Joined Oct 26, 2017
253
But is it possible to measure the voltage drop across the inductor with an efficient multimeter?
Papabravo
Joined Feb 24, 2006
22,111
Yes, but you will have trouble interpreting the result. Efficiency is irrelevant in this context. On a DC setting the meter will give the average voltage across the inductor. This is like integrating the waveform over a period. So the reading will keep changing. On the AC setting you may or may not get the true RMS value of the waveform, but again the reading will change depending on the periodic nature of the waveform and the period over which the integration (averaging) is being performed. In short it is a pretty useless thing to do. If you are convinced it has some utility; knock yourself out and measure away. Let us know what you discover.
Electronic_Maniac
Joined Oct 26, 2017
253
Sure thanks
