I've tried to turn on small calculator (Rated Voltage : 1.5V) with charged capacitor C.
Anyway when I connected fully charged cap to load. Then voltages dropped down with mysterious reason.
In detail, I used TENG to voltage source, (TENG is a pretty similar source to PIEZO .)
To turn on rated voltage 1.5V calculator, I charged enough 2V to cap.
Next step, I connected 2V charged cap to calculator.
It doesn't work.
How can I make this situation better?
Here is the circuit diagram what I designed.
And this is voltage curve measured by voltmeter.
You can see voltage drop after connecting to load
It doesn't work.
