nrf52832 based module, it doesn't have 6v VINThat is not necessarily valid. It's a digital circuit- it takes current in spikes and fits, which is what the bypass caps are also for. An easy way to tell is put a 1-ohm resistor in series with ground and measure the voltage drop across it- this will give you the true current being used.
