No, it's not like that.Do you mean like this?
It's better to remove the extra one on its own because current from the 3 will actually flow backwards through the single one.
Also see if it gets better if you move the electrodes closer together (don't let them touch).
Do you have a multimeter?Howdy!
I made a vinegar battery very a few minutes ago. XD
I made 3 vinegar batteries (series connection) and one more.
and connect them each other by parrallel circuit.
EH? can't even light up the LED very brightly.
Whoops, that was me, wasn't it@ Lightfire
I 'll make the correction, just to prevent bad habits from sticking:
It's called a multimeter, not multimer.
I 've been calling a certain software Utilboard instead of Ultiboard. I found it out last week. It's very hard to call it correctly now.
Battery charger components repair | Technical Repair | 7 | |
Recommend low-voltage cutoff circuit for 12V lead-acid battery | Analog & Mixed-Signal Design | 14 | |
3D Battery Holder Designs Models for AA, AAA, C and 18650 | General Electronics Chat | 0 | |
| J | Apple Cider Vinegar | Off-Topic | 1 | |
Vinegar Battery | Power Electronics | 3 |
