Hi there, ive got this Car Amp and recently its stopped working, it powers on and allows pass through to other Subs with no issue.
There is a switch that says 0 or 180°
This switch has broken and now i get no output to the internal Sub.
I want to change the switch for a new one but this foam stuff is holding the board down, youll see in the pictures. What i need to know is how to prise the board away so i dont damage it and re-solder a new switch to fix the issue.
Any ideas how to lift it off so the board does not crack/break ?
or, if i cant lift the board off without breaking, how can i make a permenant bridge so that it is locked to 180°, which points will need soldering.
Any help, much appreciated.
