Via sizes for signal and power
DJ_AA
Joined Aug 6, 2021
502
Hi All
I generally use 0.3mm(hole)/0.6(Outer) via for all signals.
When using via to go to the power plane, is it better to use the same via size as mentioned above or increase the size but reduce the qty of vias?
Ervin2022
Joined Mar 30, 2022
18
When vias to planes are cosidered, whether it is power or ground, I've noticed that general tendency goes towards increasing the quantity of vias rather then their size. If I am not mistaken, geometrical calculation will support this decision.
ronsimpson
Joined Oct 7, 2019
4,777
How many holes does cost. How many drill sizes cost. If you can keep all the VIAs the same size that helps the board house.
In small volumes I have never seen a charge, but I know in large volumes everything is added up.
