MaxHeadRoom
- Joined Jul 18, 2013
- 30,884
An example may be a gantry machine where the gantry has the spindle motor mounted on it and has its normal ground conductor in its supply cable as you have mentioned.My question was, do use the existing spindle ground cable to ground the machine, or add a second, dedicated cable from frame to star ground (meaning, if we consider the spindle ground, there would be two paths to the star ground point from the frame.
This spindle may be on a slide for Z axis operation.
In this case, It also pays to ensure the gantry itself is properly earth bonded to the rest of the stationary part of the machine via a separate GND cable.
