Velocity and Acceleration
Breeze
Joined Jun 30, 2015
24
Morning to you fellow Engineers,i need help with this Assignment question on velocity-"A particle is moving along the x-axis so that its distance,x in meters,at time,
t in seconds,is x(t)=3,2 √ tan 5t. Find its velocity at time t=1,5 seconds .i know velocity is "dx/dt"in this case but i have a litlle problem with solving going forward.Any assistance in this question will be greatly appreciated.
22,111
So step 1 is to compute the derivative. How should you go about setting that up?
You might also want to learn Tex, which this site supports. Is this your position function?
\(x(t)=3.2 sqrt{tan(5t)}\)
dannyf
Joined Sep 13, 2015
2,197
dx(t) / dt = 3,2 d(sqrt(tan(5))) / dt = 3.2 * 1/2 * [tan(5t)^-0.5] * d(tan(5t)) / dt
after that, you can either use a formula on d(tan(5t))/dt, or think of tan(5t) as sin(5t)/cos(5t) and go from there.
Breeze
Joined Jun 30, 2015
24
Many thanks this is absolutely helpful indeed.
33,123
It's well worth getting familiar with. It is far, far more then just something for making formulas display in a forum -- it is intended for electronic typesetting in general. For instance, my entire PhD dissertation was written in LaTeX, many (most?) professional journals and conferences want submissions to be in TeX/LaTeX, and many book publishers require that it be used.
Breeze
Joined Jun 30, 2015
24
Thanks a lot Sir,your advice is absolutely invaluable,may i know which site i can get comprehensive info about LaTex so i can start learning it?
Russmax
Joined Sep 3, 2015
82
Thanks for the pointers on TeX. I joined the forums about a month ago, and I did not know you could do this. I've been typing ugly text formulas.
