Velman PMLED/5
Wendy
Joined Mar 24, 2008
23,798
http://www.vellemanusa.com/downloads/1/pmlcdpmlcdlpmledpmled5gbnlfresd.pdf
I have got this meter to working on my electronic load, but it is 200mv max scale. I need 2V max. Reading the manual they keep referring to Ra and Rb, but there is nothing like this one the meter, which makes me think they are thinking external resistors. If I have to go that route I'll probably buy a 10MΩ resistor and adjust it that way.
Figured it wouldn't hurt to ask other opinions first.
http://forum.allaboutcircuits.com/threads/electronic-loads.38703/
bertus
Joined Apr 5, 2008
22,925
They are a bit double in the input impedance.
In the features they say >100 MOhms and in the specifications they say > 10 MOhms.
For 2 Volts I would try RB = 9 MOhm and RA = 1 MOhms (when taking the 10 MOhm input impedance in account, RA would be 1.11 MOhms).
(the scale seems to be adjustable with R2).
Wendy
Joined Mar 24, 2008
23,798
Ra and Rb seem to be external components. I have found the decimal point select. At this point I'm looking to get either a 1MΩ or 10MΩ trimmer post. A 100KΩ would probably work as well too.
Lestraveled
Joined May 19, 2014
1,946
I bought a few of the LCD versions and they came with external resistors. Also, the power supply has to float relative to the input.
jpanhalt
Joined Jan 18, 2008
11,087
Bill, the meter is like the MPJA offerings (http://www.mpja.com/) they are external resistors. When I get back to the farm, I should have a picture somewhere to show how i did it.
Do you have the chip number available to you?
John
Wendy
Joined Mar 24, 2008
23,798
The part number is shown on the title. It is the Velman p/n.
I just have a bit of trouble believing they require external resistors. No big deal I guess.
jpanhalt
Joined Jan 18, 2008
11,087
Bill,
Here is the board I got from MPJA a few years ago. The two resistors you need to change to adjust the range are circled. They are under the chip. If your board looks similar, I can search further for the datasheet for the display chip that came with the MPJA display. The Velleman link didn't seem to have a picture. The main IC in the meter is an ICL7107CPL.
John
