VCO
Zeeus
Joined Apr 17, 2019
616
hi Z,
Check this out , I am using a 2N2819 jFET
E
Thanks thanks
Please share the .asc
Mine keeps "stepping source" dunno why
Already changed the -10k
Really wish to figure circuit myself but....
D1 and D2 is just for input protection?
At some point does current flow from through the JFET from the virtual ground? from Source to drain??
Thanks
ericgibbs
Joined Jan 29, 2010
21,443
hi Z,
There should be a FET model in your LTS Folder for a 2N3819, use that and retry the sim.
There maybe a problem with original FET 2N5458 model.
E
Zeeus
Joined Apr 17, 2019
616
hi Z,
E
Same stepping source problem
Will Download WINE to run windows 10
Thank E
Btw, kindly throw some light on the circuit
The output of 1st op amp is -vi.
This voltage is divided between r8 and r9
Now can current from the virtual ground (source) to the drain of the JFET when it's gate is 0v?
Please what is he missing?
ericgibbs
Joined Jan 29, 2010
21,443
hi Z,
Tried that, removed R9.
LTSpice cannot solve the equations so goes into a continuous loop.
So no waveforms are created.
Why do you want to remove R9.?
E
