Variac's
loosewire
Joined Apr 25, 2008
1,686
Are variac's used in the modern electronic's world of computer's.
Is there a need to isolate equipment and have external power suppy
regulation from ac spike's. LOOSE WIRE
Wendy
Joined Mar 24, 2008
23,809
They are used where their is a consistent drop or excess in voltage, to bring the AC voltage into spec. Sometimes power companies aren't consistent in taking care of these problems and it is easier to use something like this to take care of business.
They are also one of the original variable power supplies.
SgtWookie
Joined Jul 17, 2007
22,230
At a former employer, some of the assembly technicians used variacs to control the temperature range of their heavy-duty soldering irons. Not as accurate as a true thermostatically-controlled iron, but about 1/10 the cost.
