I've decided to keep it as simple as possible without trying to achieve any kind of regenerative braking scheme. I was reading an article that stated it was better for light EVs like skateboards and bikes to just 'freewheel' when no power is being used. The returns are negligable plus it adds to cogging down the motor. Useful on motorcycles and cars. You're right Wookie that I can start the project with what I need and later if I can I will see about making it super efficient. Plus I never started with the intention of making an H bridge. I just need a one-way controller.
Ive spent the last couple of days looking for a gate driver and I appreciate the one you suggest, I see its rated for up to 30 volts and my rfg70n06 mosfet needs 20 volts to drive it. A novice question here but what happens when my battery bank falls at or below 20 volts? If I have a 36 volt system then I only get 16 volts worth of drive time until the transistors become useless? The motor is from a 24 volt DC craftsman lawnmower its probably rated at a horse and a half and 50 Amps .I want to run it at 36 v dc and 30 amps. Its a permanent magnet brushed dc about 5 inches in diameter and 8 inches long. Ive built a 555 pwm from a diagram I found but in studying how to build this thing Ive come across some posts that say for this type of power switching its inadequate. I cant remember why exactly maybe something to do with the switching frequency? So a basic block diagram for my project will be a :
power supply-power regulator-pwm-gate driver-mosfets-motor
Im not sure how Im going to do the throttle other than it will be a tether cord maybe with a switch or a pot . The batteries will probably be NiMh since they can be run down alot. My cordless drill is NiMh. LiPolys cause too many fires in my opinion. This motor and controller will fit on a custom skateboard deck with one tire in the back and two in the front. The wheel in the back will be fixed and the two in front will be attactched to a mountainboard truck for the width. I'm going offroad with this puppy. My wheels are salvaged wheelchair wheels the real nice inflateable ones with profile rims lol. My drive system will consist of the motor-bicycle hub from a 3 speed-back wheel. From the motor to the hub will be chain driven, from the hub to the back tire will be belt driven. This scheme will allow me to align the motor with the back tire. Plus Ill get 3 speeds out of the deal. I only need to turn it on very little then I can freewheel. Im just concerned about a big enough battery bank to keep them mosfets working. Also, should I have a separate battery bank for the PWM side and another for the motor side? At first I was going to use the same batteries and a regulator. Thanks for taking the time to look up parts for me Wookie that was a really big help. I'm really anxious to have this thing ready by spring, I have some real nice trails I can go on where I live and also to test the max distance . For safety reasons I will incorporate a kill switch and a manual brake . Mongoose makes a real nice one I might be able to adjust to fit the back wheel. So the brake cord and the throttle will be tethered together. Thanks for all of the feedback.
