Using transformers
ScottWang
Joined Aug 23, 2012
7,509
No! I was asking because I'm watching this video on udemy and the instructor said u can apply a voltage to the secondary and call it the primary
What video, links?
Do you know what I means about the circuit, the circuit shown that you can use an AC120v to 9-0-9 Vac transformer and reverse it just let the secondary coil (9-0-9 Vac) as the primary coil (AC120V)and the primary coil (AC120V) as the secondary coil (9-0-9 Vac).
MaxHeadRoom
Joined Jul 18, 2013
30,885
Most small transformers do not mind, but one of the larger manuf such as Hammond Transformers have a caution
"Hammond Systems, strongly discourages back-feeding Industrial Control transformers, and Distribution transformers smaller than 6kVA.
Due to the use of compensated winding's in these products, the resulting voltage will vary from the rating with as much as 10%.
Max.
