The Electrician
- Joined Oct 9, 2007
- 2,970
sn00py23, if you'll change your settings so you can receive PMs, I'll message you.
Sorry, was looking around and didn't know what I was changing.sn00py23, if you'll change your settings so you can receive PMs, I'll message you.
Did you use Nodal to determine that 12V. I was at a friend's house the first time I did this and I believe I used what we were first working on but didn't think that could be right, so I left my notes there and won't be able to get them until I see them again Monday.In the first step, I get 12v at V2 (the noninverting input to the opamp), which is what you had earlier. V2=V3, so you have 12v at V3 as well. V0 should be 24v. Of course, none of the other voltages really matter, Vth is the 12v you are getting at V2. What values have you gotten for Rth in the second part?
Yes.Did you use Nodal to determine that 12V?
I personally like nodal analysis over mesh in most cases.I'm used to using KVLs to determine what my open source voltage is...
Once you have all of your equations set up you can readily solve for V1 and all of the other voltages using nodal analysis. However, recall The Electrician's hint that, with an ideal opamp, it is assumed that no current flows in or out of the inputs. Then ask yourself how much current is flowing through the eight ohm resistor, apply ohm's law, and you will know the relationship between V1 and V2. It is a bit of a trick though. If you set up all of the nodal equations it will work out just as well....so I'd like to be able to check if that 12V is true and would need V1 to do that...
No. I worked the problem out my way and AAC's way, came up with the same answer both times, and it is not in the kΩ range. Remember that you have to use nodal analysis on two different circuits. Its a lot of work, but doesn't require any guessing about where current is flowing and how the circuit can be made simpler. Frequently, if you just plunge ahead with what you know will be a lot of work, instead of trying to find an easier solution, you end up saving time and effort in the end.What I got at my friend's house was 1.something K Ohms for Rth. Is that close to what you got?
Whoa, wait a minute, use Nodal on TWO different circuits??? I'm trying it with just one. TWO???? I don't remember the Electrician saying anything about TWO circuits. He gave me Node equations for three of the four nodes in this circuit. I went from confused to lost.No. I worked the problem out my way and AAC's way, came up with the same answer both times, and it is not in the kΩ range. Remember that you have to use nodal analysis on two different circuits. Its a lot of work, but doesn't require any guessing about where current is flowing and how the circuit can be made simpler. Frequently, if you just plunge ahead with what you know will be a lot of work, instead of trying to find an easier solution, you end up saving time and effort in the end.
Yes, you find the Thevenin voltage first with the 4Ω resistor removed and nothing else changed. Then you have to come up with a second set of equations with the voltage source removed and 1 amp injected into the circuit at V2 to find the Thevenin resistance.Whoa, wait a minute, use Nodal on TWO different circuits??? I'm trying it with just one. TWO???? I don't remember the Electrician saying anything about TWO circuits. He gave me Node equations for three of the four nodes in this circuit. I went from confused to lost.
Go to your control panel.Sorry, was looking around and didn't know what I was changing.
Correct. So applying Ohm's law, 0amps * 8Ω equals zero volts difference from one side of the resistor to the other. So V1=V2.is that if there is no current flowing through the op amp that there is no current flowing through the 8 Ohm resistor?
Not into the ideal opamp, only through the four ohm resistor.But, there will need to be one you put the 4 Ohm resistor back in, right?
It is easy to make mathematical errors with these simultaneous equations. Here is how I got the first part:I put his and my last equation in three times and go a different answer each time. I used my calculator and for some reason I don't get 12V for V2.
That is the gain, not Vout. Multiply that by V2 and you get Vout (V0).If I use (1 + Rg/Rf) and get 2 for Vout how did everyone else get 12V I get Vin as 1V
I did the first Nodal set of equations with the 4 Ohm resistor removed and still can't come up with 12V.Yes, you find the Thevenin voltage first with the 4Ω resistor removed and nothing else changed. Then you have to come up with a second set of equations with the voltage source removed and 1 amp injected into the circuit at V2 to find the Thevenin resistance.
Look at my previous post.I did the first Nodal set of equations with the 4 Ohm resistor removed and still can't come up with 12V.
You are putting 1amp into V2, it does not have to go into the opamp...like this:You state that there is no current in the op amp which give me none at the 8 Ohm resistor, but now I'm supposed to put 1A into the op amp which doesn't allow current flow...
You are so close!!!Okay, putting in your 3 equations and the last one of V2=V3, but changing the V2=V3 to one equation of (V3-Vo)/10 + (Vo)/10, I came up with Node voltages of 9V, 9V, 7.5V and 15. When I took V2-V3 = 0 I got 11V for three Nodes and then 22V at Vo.
So, I'm thinking I'm close if 12V is right, but still not sure how you're getting it.
I don't know what "zero" you're referring to. Do you mean the zero in (V3-0)/10 in this sentence?I thought we were working with four Nodes and that zero you have in there has me for a loop.
The way we learned how to do nodal was to put the variables into our calculator and hit solve. I have almost identical to yours, but using yours with that zero in there gives me an error overall.
I took everything to zero and solved using Nodal format, what am I doing wrong?
Why would you want to solve for Vo? The problem didn't ask for that; it asked for the current i in the 4 ohm resistor, and you don't need to know Vo to get that. The solution to the 4 equations does give you Vo, as well as V1, V2 and V3, but only V2 is really needed to get Vth; the others are incidental to your real problem!Hallelujah! If I hadn't of already fallen from a few churches, I'd go back today! I finally got it, but how come I wasn't solving for Vo which is what I was trying to do?
I need to get something to eat and allow my brain to cool before I begin with the Rth.
Thanks bunches!
