Hi Folks,
Been a lurker but noob currently!
I have a project i need some help with:
I have a CRT computer monitor that displays an active screen that I need to have alert me when it changes. My thought is to use a phototransistor (or something else you might recommend) to detect the color change on the screen when an event has occured. This output would need to be a relay for other circuits (strobe/buzzer etc). The relay can trigger a larger relay for outside circuits if required.
The circuit would need to be simple (as I'm old and lazy and cheap
Below is a picture of what the screen looks like. Assume it's like an excel sheet that auto updates every few seconds. The top "row" is the new activity.
I want to direct the sensor at the top row in the blue area, and have relay closure when a red bar appears (primary goal) or a closure on any color change if needed or available.
Once I have closure, I will be alerted and will reset the circuit (I can manage that part of the circuit
I would appreciate any guidance on this!
Thanks
Jim
Thanks
Jim
