Using P Channel Enhancement Mode MOSFETs
howhurley
Joined Feb 1, 2009
14
Sorry for the picture, it's a screengrab. I have two logic signals that will be going LOW when active. I thought I'd use a couple P-Channel enhancement -mode MOSFETs to do this. Will this work? Is there a better way?
38,533
The top one would work (if you reverse the drain and source terminals and use a logic-level P-MOSFET) but the bottom one won't because there's not enough gate-source voltage to turn it on (even for a logic-level type MOSFET, Vgs needs to be minus 3-5V).
The easiest solution is probably to use two N-MOSFETs or NPN transistors on the bottom (the first to invert the signal, and the second to turn on the LED).
GopherT
Joined Nov 23, 2012
8,009
When you want Q1 to be active and current flowing from the 6V supply through Q1 and the LED and to the 3V supply, you have only 1mA going through the LED.
When Q2 is active, you have 2mA going through the LED. Is that going to be bright enough?
Why not make Q2 an N-Channel, life will be much easier, assuming both Q1 and Q2 will be logic level MOSFETs
howhurley
Joined Feb 1, 2009
14
howhurley
Joined Feb 1, 2009
14
I read the specs, and I have the gate voltage going LOW (near GND) when I want to turn the lights on. I adjusted the series resistors, thanks for that.
GopherT
Joined Nov 23, 2012
8,009
yes, but since Q2 is connected to ground, how can you drop the gate sufficiently below ground to turn it on?
howhurley
Joined Feb 1, 2009
14
<hastily scribbling series resistor between Q2 and ground> How about now?
It would be so much easier to have a different type of LED, I'd use the ground and 6 V, but alas...
howhurley
Joined Feb 1, 2009
14
Never underestimate a guy that has already ordered his parts... According to the chart above, if I keep the resistor value to prop the source above the Gate ground by 1.5 V, I should have about .1 ohm, and that should conduct well enough? Then I'll need to lower the 220 ohm resistor to increase the diode current to about 5 mA?
38,533
Sorry. :(
There's still no way to initially turn on the bottom transistor.
Next time you might try a simulator before ordering parts. :)
howhurley
Joined Feb 1, 2009
14
All kidding aside, I do not understand your comment. I thought that if I would be able to bring the gate voltage from -.45 to -1.2 Volts with respect to Pin 1 of Q2, it would start to conduct. Am I in error? I thought I knew how these devices work...
(and my snark...don't take it for face value...I appreciate your help.)
Jony130
Joined Feb 17, 2009
5,598
Almost every MOFFETT will have a build in body diode. And this body diode will act just like an ordinary diode.
So your circuit will look like this
GopherT
Joined Nov 23, 2012
8,009
A MOSFET needs a bigger gate voltage drop than a pnp does. It will take 2 to 5 volts for a logic level mosfet to turn on all the way. You only need a few milliamps (maybe up to 20 mA) of current so you will not need all of the turn on (you can run in the linear range instead of the fully switched on range).
An standard MOSFET (not a logic level mosfet) typically is specified for 10V of gate voltage to turn on completely. You have less than 1 volt (assuming you remove resistor R4). If you keep R4, you will never get more than 2 mA through your diodes and your voltage drop from gate to ground will be small fractions of a single volt.
Your design might work enough to light the LED if you remove R4, AND put a 47 to 100 ohm resistor between Q2 and ground.
howhurley
Joined Feb 1, 2009
14
Thanks, I had put R4 in to limit the current in the LEDs before I put the other two in. I am going to get some little SMD to breadboard adapters to figure out the fine points of this, but basically, I have a board almost ready to go to OSH-Park and just needed to get some handholding.
Thanks for BOTH of your help!
GopherT
Joined Nov 23, 2012
8,009
Oh!
If you are sending a board in to have it made, then it is worth making it correctly. Make the few fine adjustments that are needed and get an NPN or N-channel mosfet for Q2. It would be a shame if Q2 does not turn on appropriately after spending the money on a board (or boards). Send me a private message with your address (click INBOX in upper right) - I'll send you a handful of the proper components.
38,533
Note that when you invert the top P-MOSFET and use an N-MOSFET or NPN for the bottom a GT suggested, you will need to invert the bottom signal for proper operation.
Below is a bridge circuit using two N-MOSFETs and two P-MOSFETS that will do what you want with only one supply voltage, and which gives symmetrical (equal) currents through the LEDs (or you could make them unequal by changing the relative values of R1 and R3).
Wow...I guess I've forgotten a lot since college. Yes, I see how this would work better and be balanced, to boot. I'm 59, but not too old to learn (forget, maybe). Thank you both kindly for your time and effort helping me. I do have the space for the six pin Alpha and Omega parts; is there a reason you picked these, or were they just easy to get to on the simulator? I haven't used PSpice for twenty years, guess I need to install the add-on for KiCad. What do you two use to simulate?
Thanks,
howhurley
GopherT
Joined Nov 23, 2012
8,009
Thanks,
howhurley
You have two accounts on AAC?
38,533
............ I do have the space for the six pin Alpha and Omega parts; is there a reason you picked these, or were they just easy to get to on the simulator? I haven't used PSpice for twenty years, guess I need to install the add-on for KiCad. What do you two use to simulate?
I just picked those parts somewhat arbitrarily that were in my simulator library.
You can use just about any logic-level MOSFETs [Rds(on) specified at a Vgs of 5V or less].
I use the free LTspice simulator from Linear Technology.
Several on these forums use it. It's one of the better free simulators available.
Attached is my LTspice file.
