- Joined Jan 23, 2018
- 28,651
I have successfully run a 24 volt AC solenoid on a bit less than 12 volts DC to power the gas valve on a steam boiler during an extended midwinter power outage. The DC came from a partly discharged 12 volt battery, but it was enough to operate the solenoid and run the boiler for three days.Yes, you can drive solenoids with DC when they are designed and rated for DC. Below is an AC solenoid which was fed a steady diet of DC. It worked just fine for about 20 min and then stopped working.
Designed as can be seen on what's left of the label 24 VAC 60 Hz. When supplied with DC the coil heated up, the housing blistered, and that was the end of life as the coil knew it. I used this image as a part of discussing with the technicians the importance of using the correct replacement parts.
Ron
BUT the concept of transformer tap changing requires a lot more, and a micro such as the arduino has no part of it. NONE!! The systems with tap changing are done by simpler logic systems that the utility companies use, and power fets have not much part of it. Definitely a switching power supply arrangement is the suitable choice.
