Using a Microcontroller Instead of a Switch
popcalent
Joined Mar 17, 2018
144
Hi, all!
I have the top circuit, which is controlled by two manually operated switches. The circuit changes the resistance between points A and B depending on which switch is pressed. I want to replace the switches with a microcontroller, so I designed the bottom circuit. The outputs of the microcontroller are either a digital one, or a digital zero. The only voltage involved is 5 V.
Will this work? What value should I use for the base resistor?
This is just a DIY project — it’s not going to land a rocket on the moon — so I don’t need super precise values. Thanks a lot!
The SW01 needs 5.7V into base at least to went into saturation.
Also some Ib current will be added to Ic current (output), so it will cause some output error.
I would use an optocouplers instead bjts and you are good.
sghioto
Joined Dec 31, 2017
8,751
Proposed suggestion using a CD4066 quad bilateral switch.
Switch A is normally ON as control A is high through R3 when both micro 1 and 2 are Low. Output = 50K
Micro 1 ON: turns ON switch D, Output = 0 ohms.
Micro 2 ON: turns ON switches B and C.
Switch C turns OFF switch A by pulling control A to ground.
Switch B ON and switch A OFF, Output = 100K
