Hello All
Im after some help and information for the following.
Im installing some usb ports in my minibus. Im making everything from scratch (intergating the usbs into some existing components thanks to the 3d printer) . Id like the ports to be quick chargers at the least and there is no requirment for data transfer.
The van has a 12v supply that i will be using. Are there any converters or inverters (magic boxes) that i should use to ensure the volts, amps are the right level.
Thanks in advance sorry if its not making sence
