Urgent HIP4081 Issue
gv260ea
Joined Apr 8, 2015
5
Hi, Recently i've been developing a motor driver bıard with the HIP4081. I'm applying PWM to the BHI pin and 3.3V to the ALI pin. My mosfets are IRFS7437 and there is a 15ohm resistor between their gates and the driver pins. I do not get the pwm out of the mosfet. The first photo is the output pin under load and the second pin is the gate pin of the mosfet. Notice that there is an offset in the gatepin which the square wave doesn't go to GND. What is causing this issue and how can i solve it. I have also attached the schematic of the board.
ronv
Joined Nov 12, 2008
3,770
What is the part number of the opto? It doesn't look like it is pulling to ground. It might be a good idea to run it at a higher voltage (although it looks like you input is 12v not 3.3).
That schematic is almost impossible for anyone that hasn't lived with it to understand. :D
