I have a ton of toroidal cores used as chokes in a stage lighting dimmer rack, operated at 60 Hz mains power. The thought crossed my mind that I may be able to repurpose them as the transformers for my 500 VDC to 48 VDC full bridge ZVS converter I'm in the process of fleshing out. The converter has a switching frequency of 50-100 kHz. I understand that inductance changes with frequency. What I'm less clear on is how that affects the converter? What happens when a 60 Hz inductor is used at 100 kHz? I've been reading a lot about the subject, but my understanding of it all is fuzzy.
