OK here's something that i doubt anyone has seen before. here's a routine to toggle pin D12 off and on using the Arduino 1.6.12 IDE and an Olimexino 328. I'm using assembly code to do it because this method is the fastest way to toggle a pin. the instruction "asm ( "out 0x05, r21 \n" );" executes in a single clock cycle.
you'll notice that the statement "if (x%8 == 0) x = 0;" is completely extraneous, it's only there for the purpose of demonstration.
the UNBELIEVABLE part is that when i replace the number 8 in that statement with a 9 or larger number, the output on pin 12 stops working.
it would be nice if someone else could test this on a 328 to see if they get the same result.
Code:
int x; // toggle pin 12 at .5Hz
void setup() {
asm (
"ldi r20, 0 \n" //load register r20 with 0
"ldi r21, 16 \n" //load register r21 with 16
: : : "r20","r21" //compiler directive to reserve the two registers
pinMode(12,OUTPUT); // port B, pin 4
void loop() {
asm ( "out 0x05, r21 \n" ); //write '0' to portB
delay(1000);
asm ( "out 0x05, r20 \n" ); //write '10000' to portB
delay(1000);
