Ultrasonic flow measurement is an extremely complicated topic. The density of the fluid, particulate matter, pipe type and diameter, and type of fluid, all have an effect on the reading.Hi,
can anyone point me in the direction of good books, papers or websites to look at to pick up the basics of how ultrasonic transducers work?
My top-level interest is in how ultrasonic flow-meters work with liquids.
Thanks
Bazz
That may need a new topic, ultrasonic isn't very useful at a distance. If you can re-word your requirements in a new topic, members with more experience in power line transmission may be able to assist.Hello all
I would like to know this also, i dont know for sure but some
have to be wire wrapped as to much heat from soldering iron
destroys them.
I want to use them to detect sparking on power lines.
And for all the fascinating sounds from insects and birds.
it's a whole new world.
Thank you all
Kind regards.
Are you referring to piezo transducers? If so, one approach to soldering them is to use Wood's metal rather than conventional solder. It has a meting point of around 80'C; needs a flux. Works well I think.Hello all
destroys them.
Thank you all
Kind regards.
OK, but being a bit more specific, what sort of dimensions would be needed to work successfully at 2.8MHz? Although I have found reference to transducers working at frequencies as high as 48MHz, the detail tends to be highly proprietary! Also, in order to place a piezo element some distance from a very hot fluid, solid waveguides need to be used, which of course are rather different to a diaphragm.Ultrasonic transducers work the same as any other acoustic transducer.
It's just that the dimensions are different to suit the smaller wavelengths.
For example early echo sounders used small metal diaphragm Tx, similar to but much smaller and flatter than loudspeaker cones.
OK, thanks for that- will check it.The textbook
Ultrasonics by
Dr P Vigoureux of the Royal Naval Scientific Service
Has a chapter on transducers and a chapter on ultrasonics in various (inc organic ) gases and a similar chapter on liquids.
go well
