I am working on a project involving the use of a Piezo Ceramic Ultrasonic transducer which is rated at 35 watts. I am able to adjust the power supply to a lower output, but since the transducer is not adjustable, will it put out the same amount of power that I would be supplying to it? Ex: If I reduce the wattage to 5 watts and supply that to the transducer, will it also emit 5 watts?
