Uhf/vhf/fm coax connectors for home made hd antenna
Ylli
Joined Nov 13, 2015
1,088
Because best power transfer occurs when source impedance is same as antenna, and free space impedance is 377 Ohms so 75 Ohm antenna would give very poor results.
I know this is an antique thread, but that statement bugs me. A properly tuned and matched antenna acts as a transformer in that it matches the impedance of free space to the impedance of the transmission line. The impedance of the antennas output port has no bearing on the antennas efficiency.
SamR
Joined Mar 19, 2019
5,054
Several factors involved, impedance and frequency being the most important. Actually the impedance is, of course, dependant on the frequency. Typically a Balun is used between the feed coax and the antenna to match the impedance and the antenna tuned to resonate at the transmit frequency. To put it in a nutshell.
Janis59
Joined Aug 21, 2017
1,849
RE:<<can you step dowt the ohms by adding a resister and by passing it all together and just solder it?>>
No, You cannot.
If want to know better then read anything starting with "Smith chart". The only knewn method have name "to tune".
Actually it does. https://en.wikipedia.org/wiki/Radiation_resistance
You properly tune and match the transmission line to the feed point of the antenna. The impedance of free space and the antenna Radiation resistance might be widely separated.
Papabravo
Joined Feb 24, 2006
21,228
Impedance matching is more critical in a transmitter than in a receiver. Most communications receivers will adequately receive a signal from a random length wire tacked up on a wall or strung out of a window. A typical "weak" signal at the antenna might be -120 dBm or about a femto-watt. A good receiver can turn that minuscule amount of power into a usable signal without even breaking a sweat. for a receiver, impedance matching is a complete waste of time. For a transmitter, it's a completely different story.
True for casual communications.
It's important for signal integrity when you have 100's of receivers connected to a receiver antenna farm the size of a football field.
Papabravo
Joined Feb 24, 2006
21,228
Is that hundreds of receivers connected to a single antenna, or hundreds of receiver/antenna pairs with the antennas in close proximity (within 1-2 wavelengths)?
