What is the difference between them? At what max frequencies can rectify ac current?
The UF4007's reverse recovery time is almost 20 times that of the 1N4148; and it has 4 times the junction capacitance. So yes, the 1N4148 is "faster."So the 1n4148 looks to be faster right?
Because that is not something determined by diode characteristics alone; it depends on the particular circuit in which it is used, the voltages across and current through the diode, and the characteristics of the other components in that circuit.But how u can see their frequency limit that they can rectify?
About 330v AC full wave with x6 stage for each cycle for total of 12 stages to generate about 4kvYou did not say what voltage you are aiming for and how many voltage doubling stages.
If you want to rectify that high a voltage, why were you asking about a low-voltage 1N4148 diode.About 330v AC full wave
Diodes intended for switching mode power supplies would be a good choice because they are intended for high frequency higher current applications. For those, check the Texas Instruments (TI) website. A 1N41418 diode is a signal diode and not suitable for most power applications. And a 1N4007 is a 1 amp 600volt power diode for ac line powered supplies. A quite good part for 60Hz applications.So has anybody any idea on what diodes can be used for the above circuit at about 50khz ac frequency?
Say WHAT???The UF400x series is quite a good choice for what you require. They are fast enough to keep the reverse recovery loss quite low, easy to get and inexpensive. I've used them in switch mode power supplies at over 100 kHz. You might find something a little better from Diodes Incorporated, Vishay or ON Semiconductor, but I doubt if you'll find anything much better that isn't quite a lot more expensive. There are very few really fast diodes similar to the 1N4148 rated at more than 200 PIV. Silicon carbide Schottky diodes are really fast but also expensive.
EDIT: Last time I ordered words, I accidentally ordered twice my usual quantity of "quite" which was quite silly because they take quite a lot of space to store so I'm quite anxious to use some of them up quite quickly.
I think that's quite sufficient Saturday silliness for now.
