I'm able to connect my Mac to serial devices (e.g. blemate2) using the ft232r, however I'm having issues getting my PIC 16f1829 to connect to the Mac via the ft232r. When I send a byte from either end, I see a response on the other end but it's the wrong data, (When I send an 'A' from the terminal program on the Mac I get 0x78 in RCREG). I thought it was a baud rate issue but I've read everything in the data sheet and tried multiple permutations and still no luck.
Here's my hardware connection setup. My PIC is running at 5V, FT232r switch is in the VCC position (as opposed to 3.3v). I have the grounds on both connected (no VCC connection should these be connected?), and both the tx-rx's connected.
Here's my code:
I can connect the tx and rx from the PIC and send and receive the correct data. Just no luck sending to the FTDI chip or or the BLE radio.
Any help is appreciated!
Thanks!
-Russ
Here's my code:
Code:
#define _XTAL_FREQ 8000000
void UART_setup()
// select TX and RX pins
TRISB7 = 0; // TX Pin set as output
TRISB5 = 1; // RX Pin set at input
TXCKSEL = 0; // TX on RB7
RXDTSEL = 0; // RX on RB5
ANSB5 = 0; // clear analog
// set baud rate
//SPBRG = ((_XTAL_FREQ/16)/9600) - 1;
SPBRG = 25;
BRGH = 0;
BRG16 = 1;
// enable Asynchonous serial port
SYNC = 0; // Asynchronous
SPEN = 1; // Enable serial port pins
// prepare for transmission and reception
TXEN = 1; // enable transmission
CREN = 1; // enable reception
// select 8bit mode
TX9 = 0;
RX9 = 0;
char UART_get_char()
if(OERR) // check for Error
CREN = 0;
CREN = 1;
while(!RCIF); // hold the program till RX buffer is free
return RCREG;
void UART_send_char(char bt)
while(!TXIF); // hold the program till TX buffer is free
TXREG = bt; // load the transmitter with the value
void UART_send_string(char* st_pt)
while(*st_pt) // if there is a char
UART_send_char(*st_pt++);
void do_BLE_frame()
//UART_send_char('A');
//UART_send_char('B');
char get_value = UART_get_char();
if(get_value == '1')
blinkRate = 115;
else if(get_value == '0')
blinkRate = 115/2;
Thanks!
-Russ
