Type Of capacitor
shivani14079ee2014@gmail.
Joined Nov 17, 2021
6
Which type of capacitor should be used at the output of flyback converter and in the auxiliary winding? Output voltge is 12 volt and capacitance is 280 uF. For auxiliary side voltage rating is 375 volts and capacitance value is 6.35 uF
DickCappels
Joined Aug 21, 2008
10,661
Low ESR (Equivalent Series Resistance) electrolytics are often used for that and should work for you. Be aware of the often-overlooked ripple current rating of the capacitors you select.
