Two Marshall speakers for better stereo?
hexreader
Joined Apr 16, 2011
619
It is a physical port (opening) in the sub cabinet which increases the output volume, but can reduce the transient response and make the bass sound somewhat muddy or boomy.
It works well if you want maximum volume for rock music or movie sound effects, but not so good if you want accurate music bass sound.
It can be in the form of a tube into the cabinet.
It may be behind the speaker grill.
Ah ... got it
Port is really obvious rectangular holes at front of speaker ground level
Should I have bought fully sealed no-port speaker?
Will that give me "punch"
Sorry for dumb questions, but I am willing to learn
I already learnt a lot from this thread
Many thanks
Link to subwoofer is below
Behringer VQ1800D 18'' Active PA Subwoofer at Gear4music
38,801
A fully sealed sub would give better transient response and thus likely better "punch", but they are not generally as loud at their maximum output.
But you can try plugging the port in your sub to see if it makes a difference.
hexreader
Joined Apr 16, 2011
619
Now that is definitely worth a try!
I will update this post when I have tried it
Many thanks
Problem was not ported vs sealed
Problem was £30 coax to RCA converter introducing noise and killing audio "punch"
Bought £200 Fosi ZD3 DAC and all speaker problems solved
Noise reduced to indetectable and suddenly drums sound great and "punchy"
Lessons learned:
1) Stereo requires two speakers separated in real space, not bullshit ambience claims from a single stereo speaker
2) Source matters - no tech can fix crap input or crap components in the audio chain
3) Balanced is good - makes noise reduction much simpler
Next mission: - find a way to make headphones loud and punchy like speakers
Impossible mission, but will try to get close. I suspect that no headphones in existence will shake the floor with bass
Inputs from forum members who have headphone ideas will still be much appreciated
Many thanks, Hex
Problem was £30 coax to RCA converter.
Lessons learned:
Many thanks, Hex
Lesson 1). It's the room (the physical space and speaker placement) that make for great sound.
hexreader
Joined Apr 16, 2011
619
Don't have the luxury of dedicated room or choice of speaker placement, just Man-cave as I find it
Not looking for great sound, just good sound for my tin ears, which I already achieved to my satisfaction (so far)
Building audiophile listening room is not an option for me
Current issue is good, clear, punchy sound for headphones within approx. £1000 budget.
Appreciate you trying, and replying though
I have learned a lot from this forum already and achieved good results
Can you help with headphone advice please?
You don't need a dedicated room, just one that doesn't make good equipment sound bad. Can't help with headphones.
hexreader
Joined Apr 16, 2011
619
Appreciate the reply and the honesty. Thanks
All about headphones now...
... iFi Audio ZEN CAN 3 on order - living hopefully :(
New request is ... What headphones should I buy, around £200 to £1000, LOUD, Punchy, big bass, balanced/unbalanced don't care
open back, closed, don't care as wife will be downstairs
Above headphone amp claims up to 2W drive.
28,247
A word of caution, probably way too late, is that too much loud sound, either from speakers or nearby arms firing,(not practice, real conflict) will cause eventual hearing damage that for some reason gets worse long after the exposure ends. The isolation due to damaged hearing is rather bad. So unless the goal is to be isolated, I suggest caution.
hexreader
Joined Apr 16, 2011
619
Thanks MisterBill2
Good advice that may go unheeded....
I am 67 years old and already limited to about 5kHz hearing range. Willing to take a bit of a risk, as loud music is one of my few remaining pleasures :)
Will take the precaution of filtering out high frequencies, as my understanding is that they can cause hearing loss even though I cannot hear them.
