ebeowulf17
- Joined Aug 12, 2014
- 3,307
I've come up with an arrangement which uses two different string lengths and a transistor cut-off to limit current without spending too much time in the linear region.I don't know how they get this voltage, but in my technical specification it is mentionned that I should use 135 VAC maximum voltage in mode Bright.
In the lower voltage range, only the shorter string is active, because the combined Vfs of the longer string aren't overcome.
In the higher voltage range, the longer string starts conducting, and current through it activates a pair of NPNs which cut off current through the shorter string, preventing it from being overloaded by the higher voltages. It's not elegant or pretty, but it just might work. It would take some tweaking to get the exact brightness levels you want, but I think the basic concept is feasible:
