TTL
Bordodynov
Joined May 20, 2015
3,431
A more correct to say: TTL gate with open collector output. Just knowing it is "open" collector. "Open" means naked, nothing further for him not to join.
hp1729
Joined Nov 23, 2015
2,304
what are the advantages of open collector TTL
Normally TTL outputs are either actively pulled high or low. Open Collector outputs omit the high side driver, allowing multiple outputs to be tied together. Open collector outputs are also used to drive outputs at a higher voltage than VCC to drive relays, and such.
Look at data sheets for 7405 (OC, but VCC voltages), 7406, 7407, 7416, 7417.
md yasir
Joined Sep 14, 2015
16
thanks @hp1729
ian field
Joined Oct 27, 2012
6,536
In 1970 they may have had advantages over the competitive products which were RTL and DTL, but now maybe not so much.
With open collector, you can add a common base (or gate) output stage to make it a casc_c_ode - then the voltage limit is that of the added transistor (MOSFET).
This arrangement was used on the TTL video output on the Atari monitor to directly drive the CRT cathode.
OC outputs are usually rated 15 or 30V, so lamps or relays etc can be tied to a higher voltage than Vcc.
md yasir
Joined Sep 14, 2015
16
:-0
