Trying to remove timer from Sonicare toothbrush
tindel
Joined Sep 16, 2012
939
Your only chance is probably to remove the crystal (Y1). I'm guessing it's a watch crystal and it might be what sets the timing to turn off. That's the only shot you've got though.
DickCappels
Joined Aug 21, 2008
10,662
I second Kubeek's comment in post #1. Perhaps you can use the entire PCB assembly and extract the timer information you need and just the other parts go along for the ride.
akraintz
Joined Dec 8, 2017
Thank you for your help everybody. What I ended up doing was adding a dc power supply pumping in 2.5v in parallel with the batteries. This allowed the motor to run continuously for long period of time without kicking the processor into a 'charging mode'. Then I noticed there was a change in voltage across the button contacts when the toothbrush was on. I soldered leads on the two polar ends of the contacts and set up a circuit to monitor the change of voltage. Using an Arduino, if the voltage change (ie the toothbrush turned off) I would add a voltage to another circuit that shorted the terminals for the button to turn the toothbrush on.
spinnaker
Joined Oct 29, 2009
7,830
How long do you need to brush your teeth????
