My cohorts and I have run across an odd problem.
We're installing (among other things) phone lines in hotel rooms. One suite has a length of CAT5e coming in from the 110 block in the building communications room, which is T-tapped via scotch-locks to three RJ45 outlets.
When we test each of the two cables in the room without scotch-locks in place, our DSP4800 indicates no problems - headroom on the order of 8 or 10dB. Similar good results testing with DSP4800 between the "close" jack and the 110 block.
When everything gets "beaned" together with scotchlocks, and double checked by TWO journeyman technicians for correct wiring, the DSP4800 comes up with "wiremap" error. Says we've got an open orange pair at two-hundred-some-odd feet. Now, we don't expect to pass any CAT5e test with the T-tap in place, but we should at least pass wiremap, should we not? Also, we get random readings with a simpler tester - an Ideal LinkMaster. The Linkmaster alternates between opens (sometimes green, sometimes orange), shorts, voltage present, and pass. The DSP4800 gives only the open - no voltage present.
I know that we increase stray capacitance by T-tapping, but would that alone be enough to cause such odd test results?
Also, there are three such rooms wired identically - one on top of another. It is the lowest floor - closest to the 110 block - that is giving us trouble. The other rooms test just fine.
Are we going to get reliable dial-tone in this room?
