Triac motor speed control question
precisionmarine
Joined Apr 27, 2015
5
I'm trying to repair a triac motor speed control circuit that is inoperable due to a power spike and is NLA from mfg. It's based on an AC16F triac that tests bad, the gate of which is triggered thru a TO-92 component marked N313. The outside leads of N313 are marked A1 and A2 on the board.
I've not been able to find info for testing or replacement of N313, can anyone help?
Thanks!
30,726
If you want to test a Triac off board then use a low voltage AC such as a small transformer 6v-12v etc connect the A2 to AC in and A1 to a suitable lamp to the AC return, then momentary connect a 33ohm resistor from G to A2 and the lamp should light if the Triac is good.
Equivalent replacements are available from DigiKey.
precisionmarine
Joined Apr 27, 2015
5
Max, thanks for the reply. I may not have been clear, but I know the triac is bad. I need help identifying the N313 component and sourcing a replacement.
Did I supply enough info, or is a schematic needed?
precisionmarine
Joined Apr 27, 2015
5
Thanks for replies. In retrospect I should've mentioned N313 has 3 leads with center lead active in the circuit , so a small signal triac is possible. I cannot find a spec sheet or other info online foe N313. If a schematic is needed I'll have to post one tomorrow when I'm at home.
ian field
Joined Oct 27, 2012
6,536
Thanks!
There's an old tradition of using a diac in the gate circuit - but the American semiconductor industry came up with all sorts of variations on the 4-layer device theme.
You could maybe try the DB3 diac:
http://www.farnell.com/datasheets/1689752.pdf
precisionmarine
Joined Apr 27, 2015
5
Ddave, the gate of the AC16F triac is connected directly with what is labeled A2 (on the pcb) of the unknown component N313 (a TO-92 based component)
So I'm trying to identify N313 for testing/possible replacement. Best guess so far looks to be a small signal triac. I'll upload a circuit drawing tomorrow if I haven't figured it out.
Thanks for all the interest and replies, I appreciate the effort on my behalf!
ian field
Joined Oct 27, 2012
6,536
The most likely is a small signal triac with no external connection to its gate - its triggered by a specific breakover voltage.
Or in other words - a diac.
Hello Precisionmarine:
I have a PCB:G.S. H.L.LI. PY3H-01
Can you tell me what part number use for replacement a N313 (Small Signal Thrystor)...
And can you help me with the value of resistor R4, R2 and R3...
I receive this PCB with burner a resistors and burn a N313.
I appreciated very much your help. Thank you very much..
ian field
Joined Oct 27, 2012
6,536
The only diac I know of still available is the DB3. Breakdown voltage is somewhere around 32 - 34V. They usually come in the same size diode package as the 1N4148, they're frequently blue and have no cathode marker band. They have also started turning up in SMD package. If you can't find a supplier - many CFLs use one in the start up circuit.
Motorola did a large range of 2 pin TO92 trigger devices in various breakdown voltages, both polarised and bidirectional. Whether they still do is another matter.
