TRIAC Circuit Explanation
Randa Mohamed
Joined Jun 19, 2015
25
Hello everyone
I have a project where im using TRIACs to switch several AC voltages from a transformer.
I found the following circuit and I need help in explaining how it works assuming that LIVE and NEUTRAL are from the transformer.
Randa Mohamed
Joined Jun 19, 2015
25
Actually i don't want to use this PIC. My plan is to control the TRIAC via an opto-coupler. I'm concerned about the TRIAC and transformer connections. I'm interested in TRIAC functionality. Please explain to me how it should work in such case. Do I need to use a zero crossing detection circuit ?
ian field
Joined Oct 27, 2012
6,536
You need the right kind of opto-coupler with AC output (opto diac) connected from gate to the MT furthest from the gate via a current limiting resistor - the value could be 100 - 180R depending on the mains voltage.
Randa Mohamed
Joined Jun 19, 2015
25
Thank you all for replying
Look up Fairchild App note AN-3006.
Shows the use of Zero crossing and random phase drivers and opto's.
@MaxHeadRoom Looking at the Fairchild App was very helpful and it clarified some concepts. @ian field I think the below circuit is what you were talking about.
I have some questions regarding this circuit from the app note a3006
Is the snubber RC is for the triac only or do i need another snubber to protect the optocoupler. Why they have connected the snubber circuit that way? Why not use an RCD snubber ? And how they got the values for the RC circuit ? do these values depend on the load only and how is that ?
How are you going to sense the Zero crossing, can you not use a simple triac dimmer circuit....?
[/QUOTE]
@Dodgydave I'm currently trying to design a voltage zero crossing circuit to turn the triac on and a current zero crossing circuit to turn it off. I'm planning to use comparators.
30,663
The snubber is used to prevent spurious switching noise on the AC line, however with zero cross turn on and off type switching it may not be relevant.
ian field
Joined Oct 27, 2012
6,536
Wherever they come from - transients can unintentionally trigger a triac, they have a Dv/Dt specification stated in the datasheet.
The marketplace has had for some time - "snubberless triacs". Probably worth a look.
Lestraveled
Joined May 19, 2014
1,946
Here is a simple zero crossing circuit I like. It uses a bi-polar opto-isolator. You can use two normal opto-isolators in parallel and get the same result.
Are you looking for just on/off, or are you looking for a dimming function?
ian field
Joined Oct 27, 2012
6,536
Those AC input optocouplers were fairly common in modems.
Look for any PC internal modem cards that don't have a bridge rectifier in the input section.
30,663
The OP mentions full phase on/off zero-switching, no phase angle control.
You need a sync circuit as per the PDF when using a Pic.
The MOC316x are zero crossing opto's.
Randa Mohamed
Joined Jun 19, 2015
25
From my research the on/off switching noise depends on the load, if the load is resistive then the voltage and current are in phase so having a voltage or current zero crossing circuit is enough. My aim is to switch on/off an inductive load where the voltage and current aren't in phase. Basically the triac should switch on at zero volts and switch off at zero amps.
@ian field First time to hear about "snubberless triacs" I'll research about
Well this circuit should do, my aim was to convert the voltage and current signals into squarewaves using a comparator then detect the falling edge part using an xor gate, i think its gonna be more precise.
