transpose to 12v
happysoul
Joined Sep 9, 2014
28
the forward voltage is 1.8v to 2.1v, the purpose is the led on the base is a flickering led, like a candle but not very bright hence the 1 watter.
happysoul
Joined Sep 9, 2014
28
Yep works perfect on 5v, I tried it with the resistor changes only have a bc327 at home, but doesn't work, the brighter led just stays on, no flicker, maybe the transistor
18,108
It's not the transistor (assuming it isn't damaged and you have the pins right). You need to tweak the base resistor to get it to turn the transistor on and off with the flicker. Too small and it's always on, too large and it won't go off.
Alec_t
Joined Sep 17, 2013
15,119
Good point, Wayneh. Perhaps try ~1k-2k?
