Translate the size of these capacitors' PCB packages
ArakelTheDragon
Joined Nov 18, 2016
1,366
Hi guys!
I have a hard time translating the PCB sizes of these capacitors. Maybe I am just asleep. What does "0.39*0.19" means for the diameter? I know there is no pitch too. Is this in inches, cm?
ArakelTheDragon
Joined Nov 18, 2016
1,366
Radial.
10*5/0.39*0.19
10 = pieces, what is "5mm"/what is "0.39*0.19"?
It should be "Length by diameter"? In which case its Length = 10, diameter = 5mm. The pitch is still missing.
bertus
Joined Apr 5, 2008
23,009
10 * 5 mm is the same as 0.39 * 0.19"
Again is the capacitor radial (leads on one side) or axial (leads on both sides)?
Is there no datasheet of the capacitors?
The datasheet should have that information.
Bertus
djsfantasi
Joined Apr 11, 2010
9,237
Radial.
10*5/0.39*0.19
10mm or 0.39” is the length (or height in the case of radial) of the cap body. It an unfortunate coincidence that 10 is also the quantity.
5mm or 0.19” is the diameter of the cap body.
I just figured what you meant by pitch... the distance between leads. It is indeed missing. What are you using for the PCB layout? I’d either find a similar cap or order then and measure it yourself.
dl324
Joined Mar 30, 2015
18,476
The distance between the leads has to be measured or guessed.
Instead of buying blind, contact the seller for more information. If these are on AliExpress, those people often know little about what they're selling and, in my experience, aren't responsive before or after a purchase.
They should give diameter, length, and lead space...
For the price its wort the risk.
Chinese sources are infamous for selling counterfeit parts.
narkeleptk
Joined Mar 11, 2019
599
good caps are already cheap enough, no reason to put up with poor information if you need them for something important.
I would only buy this if it was just for basic testing/breadboarding purposes in which case the size/spacing isn't all that important.
