Transistors Collector-Emitter Voltage
Bogdan_Ionut
Joined Oct 5, 2021
9
I have some 2n2222 TO92 NPN transistors. On datasheets, the collector-emitter voltage is 30V. My question is, this value is the upper limit, It should work with 12 V, the idea is not to exced the limit, is that correct?
BobTPH
Joined Jun 5, 2013
11,637
If you look at a datasheet, that will be listed under “Absolute value Maximum Ratings.” That should be a clue.
Bob
