Transient Response Calibration
MikeML
5,444
Use a big NFET to connect/disconnect a several amp resistive load to the power supply. Measure the step response of the PS as the NFET turns on/off.
This illustrates the concept. Note how bad it is without a bypass cap on the output:
Ryne Shelton
Joined Feb 20, 2015
4
I'm in a calibration lab. I'm also new to the lab so I'm not familiar with everything in it yet. Everyone else is gone.
I'll look around and see what I can come up with. Thank you for the help.
38,513
Even a toggle switch should work to connect and disconnect the load.
The contact bounce on make should be tolerable for this test.
Ryne Shelton
Joined Feb 20, 2015
4
Thanks for the info guys. And yes, we do have single-event recording o'scopes. I'll try it on Monday when everyone is back in the lab and let you guys know how it goes. Have a good weekend.
