Transformer Size China V UK
tried
Joined Mar 27, 2013
11
Why are the transformers in the DC power supplies from China so small, in a 12v 10 amp supply I purchased it is about 30mm square compared with a 12V 1Amp transformer I have that is about 80 mm square? Have I missed something?
recklessrog
Joined May 23, 2013
985
Maybe the Chinese psu is a switched mode type does not have a "mains" transformer. Transformers working at 50-60 Hz 10 amps require a lot of iron, and even 1amp makes it fairly large compared with an inductor working at several hundred kHz.
DickCappels
Joined Aug 21, 2008
10,152
Another thing to consider is that there is generally a trade-off between cost and characteristics such as temperature rise, regulation, and of course efficiency. The less suff used the less it costs to make, and some manufacturers cut cost to the bone by eliminating safety and performance margins.
tried
Joined Mar 27, 2013
11
I have purchased a switched supply and now understand just a little bit more about them. I do have one question should I earth the secondary side -ve for safety just in case there is no isolation transformer in the unit?
Dodgydave
Joined Jun 22, 2012
11,285
No don't connect any part of the secondary side to earth, as you can introduce fault currents, as these chips use Live mains supplies.
Study different smps chips like TEA1733, UC3842 /5 series.
Alec_t
Joined Sep 17, 2013
14,280
In the majority of SMPS there is a small high-frequency transformer which provides mains isolation. It seems yours has one. Before using your supply you can confirm this by checking with a multi-meter for continuity between the mains input side and the 12V output side. There should be none; in which case you can safely ground the secondary -ve if you wish.
Dodgydave
Joined Jun 22, 2012
11,285
The only exception of connecting the Negative output to Earth is on metal frame psus, like atx to prevent shock, otherwise any plastic cases that are marked with a double square are not Earthed., they will probably have a suppression capacitor on the Negative output to mains negative input .
ScottWang
Joined Aug 23, 2012
7,397
The 12V/10A power supply, if you were not bought the industrial type, then the current could be not enough as its claimed, probably the current just around 6A or less.
DickCappels
Joined Aug 21, 2008
10,152
I see that in retail markets in Thailand all the time. Unless it is a brand you know and are cofident it isn't counterfit, be very skeptical about specifications.
tried
Joined Mar 27, 2013
11
From the out side appearance, same design perforated ali. case, same terminal arrangement all available on ebay and amazon they all look to be same. I did measure ohms from L and N to +/- its all open circuit. I think I will risk earthing the -ve side for safety.
