Thank you so much! It is for sew eurodrive . If the dimensions were ok, can i use the IEC60950 information for testing it?Hello there.Welcome to AAC! not 100% please confirm physical dimensions. Any information on the control board itself manufacturer? perhaps?
JBC-3114-EF25-1
Yes, I hope it helps, good luck to you.Thank you so much! It is for sew eurodrive . If the dimensions were ok, can i use the IEC60950 information for testing it?
by Jake Hertz
by Robert Keim
by Duane Benson
