TIP35C ???
R!f@@
Joined Apr 2, 2009
10,004
I am confused....???:confused:
Is TIP35C a darlington ?? The data I have says NO! :D
This I wanna Buy. :rolleyes: I do not want darlingtons.
But this says it a darlington.. o_O
So what is it ???? :mad:
R!f@@
Joined Apr 2, 2009
10,004
My datasheet says it is not a darlington.
I was searching on Aliexpress and Ebay and both sites most seller is saying darlington. So I thought I ask around before buying.
Thanks though.
30,661
Even if you don't buy from Digikey, their search when found also includes the PDF which avoids many of the surplus supply houses coming up when looking for a semi PDF.
It shows the TIP35C as a complementary to TIP36C PNP.
bertus
Joined Apr 5, 2008
22,925
The first site has a very wierd description for the TIP:
  • Model Number: TIP35C
  • Type: Voltage Regulator
  • Condition: New
  • Supply Voltage: International standard
  • Dissipation Power: International standard
  • Operating Temperature: International standard
  • Brand Name: new
  • is_customized: Yes
  • Application: pcb
Asif the transistor is a voltage regulator.
Also the line International Standard also tells you nothing about the part.
The second site tells no specs at all.
If you want the specs of a part, always try to locate a manufacturers datasheet.
R!f@@
Joined Apr 2, 2009
10,004
I have the Datasheet, from that I was searching for the part. But the more I looked the more confused I got.
Any ways I already bought that part since it is not a darling....
DickCappels
Joined Aug 21, 2008
10,661
It is likely that many of the merchants selling electronic components and small assemblies on eBay and Amazon do not have any understanding of what they are selling. They appear to throw in many buzz words that might seem relevant, especially if that buzz word was used by a competitor. "If their transistor features Darlington then all of ours will too!"
R!f@@
Joined Apr 2, 2009
10,004
Well guess what ?
I bought by looking at the picture from another seller cause it was a bit cheap.
Just in case I msg him saying to send exactly as the picture. He replied now he have these and shows a picture of a fake type.
Bummer..! I yelled at him and warned him to report to Ali express if he is showing misleading listings.
I guess I will have to cancel and by from the original one I showed in post #1.
But before buying I msg him to confirm his item is as shown in the picture
R!f@@
Joined Apr 2, 2009
10,004
Umm ! I am confused.
How did this thread belong to Analog-and-mixed-signal-design-forum ?
Isn't this just a general electronic related chatting ??
Just thinking out loud why it was moved ?
